Well to start off the car is a 1998 z28 a4, air intake, ported mass air, loudmouth cat back, 285 40 17 sz50 ep's, eibach pro kit.
Ok, so the drive to the track doesn't help at all being over 60 miles to get there. Track i went to rockingham in north carolina.
Talk about traction problems!!!
I had
, at all, the slowest the tires would stop spinning was around 50 mph. I did 7 runs, most one right after the other, waited 15 minutes between a few of them. I forgot to drop the tire pressure in the rear, so it was at 40 psi. I tried dropping it when i remember too, but it was too late they already did last runs.
I know i have to get the lower control arm relocation brackets.
Well here's the slips from the 7 runs, any suggestions on what to do? I know some of you guys helped me out last time i had my slips up here. Runs 4-7 were one right after the other.
run 1,
60: 2.446
1/8th: 9.637 @80.36
1000: 12.258
1/4: 14.474 @101.45
run 2:
60: 2.834
1/8th: 10.349 @78.86
1000:13.012
1/4:15.264 @99.91 This run i fish tailed so bad i almost hit the wall!!
run 3:
60: 2.267
1/8th: 9.057 @82.53
1000: 11.636
1/4: 13.837 @102.04
run 4:
60: 2.578
1/8th: 9.912 @79.58
1000: 12.556
1/4: 14.787 @ 100.76 this run i did drive shifted into od
run 5:
60: 2.429
1/8th: 9.646@80.34
1000: 12.272
1/4: 14.490 @101.35 this run was 2nd into drive
run 6:
60: 2.293
1/8th: 8.986@83.25
1000: 11.553
1/4: 13.738 @102.69 BEST TIME
run 7:
60: 2.670
1/8th: 9.995@80.19
1000: 12.621
1/4: 14.840 @101.31
I had
, at all, the slowest the tires would stop spinning was around 50 mph. I did 7 runs, most one right after the other, waited 15 minutes between a few of them. I forgot to drop the tire pressure in the rear, so it was at 40 psi. I tried dropping it when i remember too, but it was too late they already did last runs.I know i have to get the lower control arm relocation brackets.
run 1,
60: 2.446
1/8th: 9.637 @80.36
1000: 12.258
1/4: 14.474 @101.45
run 2:
60: 2.834
1000:13.012
run 3:
60: 2.267
1/8th: 9.057 @82.53
1000: 11.636
1/4: 13.837 @102.04
run 4:
60: 2.578
1/8th: 9.912 @79.58
1000: 12.556
run 5:
60: 2.429
1/8th: 9.646@80.34
1000: 12.272
run 6:
60: 2.293
1/8th: 8.986@83.25
1000: 11.553
run 7:
60: 2.670
1/8th: 9.995@80.19
1000: 12.621
1/4: 14.840 @101.31
