i am in the middle of a an opti project that has snowballed. i put an electric water pump on and while trying to do it correct wanted to remove the shaft coming thru the timing cover. to do so i need to remove the entire cover and the timing chain. i see that the original is expensive because of the need to drive the water pump shaft. i am removing this so can i use any 350 small block timing chain or do i still need a lt1 specific. i was looking and a good roller set up is around 120.00 but anything for the lt1 is way more.
timing chain
The Cloyes double roller timing set can be had for $80. It is part number CL-3145. SBC timing chains are interchangeable with the LT1.
http://www.cmotorsports.com/93-97-fb...ine-timingsets
so any small block chevy timing set will work. belt drive, gear drive anything?1994 Trans Am GT
http://www.sounddomain.com/memberpage/208684/1
Ram Air hood and airbox
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
yeah i was exagreating with the gear drive. but am i wrong when i say i think i read a 10 hp gain with double roller chain set. i do not know why you would bit i swear i read it. all i can guess is less rolling resistance1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
wait a minute. i went to the part store and they had the double roller kit on the wall. it has nothing to drive the optispark. the optispadr sharft comes thru the timing cover and into the timinng chain sprocket./ the normal small block timing set does not have this.1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
Originally posted by rufrider76wait a minute. i went to the part store and they had the double roller kit on the wall. it has nothing to drive the optispark. the optispadr sharft comes thru the timing cover and into the timinng chain sprocket./ the normal small block timing set does not have this.
Comp Cams also makes the Hi Tech LT1 belt drive, however it is not cheap.
Originally posted by rufrider76yeah i was exagreating with the gear drive. but am i wrong when i say i think i read a 10 hp gain with double roller chain set. i do not know why you would bit i swear i read it. all i can guess is less rolling resistance
i just went with the stock set up. it lasted this long and i hated not replacing it while it was in my hand1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
oksy need help agian. put car all back together and it would not start. take it apart and pull the optispark. look through the hole and see the sprocket from my timing set has no provisions to drive the optispark. i am correct the xam gear should have the grooves the have missing tooth that the shaft from the optispark lines up with. my gear it is a perfect circle. what gives? it has the gear to drive the water pump!1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
Originally posted by rufrider76oksy need help agian. put car all back together and it would not start. take it apart and pull the optispark. look through the hole and see the sprocket from my timing set has no provisions to drive the optispark. i am correct the xam gear should have the grooves the have missing tooth that the shaft from the optispark lines up with. my gear it is a perfect circle. what gives? it has the gear to drive the water pump!
are we talking opti or water pump drive?
As Kevin described, there is a dowel pin located on the cam gear that protrudes to interface with the rotor base of the optispark. If you didn't align the dowel pin with the proper channel in the opti, the timing will be far enough off to have a no start condition. If there is no dowel pin, the opti will not have any engagement with the rest of the timing set and there will be a no start.
LT1 101:
He has a 94. 93/94 Opti's are not driven off the cam dowel pin. They are driven by a splined shaft that interfaces with the cam sprocket.
okay sothey must have gave me a 95 timing set. okay so where do i get a good roller set FAST1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
