A while back I had a 1441 code and you pointed me to the purge solenoid or flow detector as the likely culprits. When I reset the codes, I would run without getting the 1441 until the computer "relearned' the sensors again, then the code would activate again (usually after about 100 miles). I replaced the flow detector and got no change. I then replaced the purge solenoid and that corrected the problem for a few weeks (a few hundred miles). Now I got the code again. The problem was definately fixed for a while, the computer had relearned again and was running fine, now the code's back again. Can you give me any insight on why it would be back?
Thanks!
Thanks!
