I recently bought a brand new 1995 LT1 crate engine. pulled it apart and installed an LT4 "hot" cam kit and headersand removed all emissions stuff. the car is wired with a Street & Performance wiring harness and they reprogrammed the PCM for me taking into account all the mods. Well I just got everything hooked up and when I cranked it over it fired right up!!!!! sounds AWESOME to, But i let it idle for about 2 mins and then noticed that the pass. side header started smoking. I thought maybe there was just crud burning off of it (and there probably was) but then the header started to turn blue, but the temp felt the same as the drivers side header. I havent ran it since. Is this normal for headers to turn blue? if so, why just this side? or maybe the PCM hasnt had time to adjust properly and i should run it longer? I dont know.
BTW all sensors are brand new and no vacuum leaks except "maybe" the T.B. gasket as this was the only gasket on the whole engine that I reused
Thanks alot
Thanks alot
