94 TA knocking and bogging down
  • 94 TA knocking and bogging down
    I have a 94 TA with 85000 miles on it that is knocking and bogging down when accelerating under load. It seems like the drivers side cylinders are cause of knock. I have taken a freescan sample and can see the knock count go up dramatically when this happens. Is there anyway to tell if this is an optispark problem or can anyone analyze Freescan readings.
    I assume your talking spark knock........whats the advance? How about fuel pressure and O2 readings?
      Here are some of the readings from Freescan.
      RPM Road O2 L O2 R BLM BLM L BLM R Intergrator IAC
      Speed Cell L R
      2150 14 0.675 0.107 7 135 130 123 132 85
      1475 17 0.049 0.084 14 139 145 132 134 87
      MAP TPS MAT Knock Knock Volts Air Spark Coolant MAT
      Volts Retard Count Flow Timing
      0.48 20 2.29 4.3 10495 12.6 33.47 41 95 47.8
      0.89 36 2.29 13 11410 12.5 52.97 5 95 47.8
      Format didn't come out well
        If you want to e-mail me the FreeScan file, in .csv format, I'll be glad to take a look at it for you. My e-mail is linked in the post. Be sure to identify the subject of the e-mail with your screen name, so I know I can open the attachment.
          Man, you are too
          '95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
            Fred thanks for the help. I sent you an email with the .csv attached.
