My car is feeling sluggish, almost as it was before I replaced the fuel pump. I looked at my MAF readings on the scanner. This is the 95 PCM programmed by MadZ28.com. The MAF is reading 9 g/sec at idle, but it maxes out at 99.9 g/sec at about half throttle and doesnt go any higher with more throttle. If im not mistaken, it should be much higher than this. Do you guys think its a bad MAF or something else? Filter is clean, and no air leaks.
If I do have to replace the MAF, is it worth it to buy one of those fancy granatelli sensors? Anybody have any experience with those??
It ran pretty hard and the O2 readings were over .9 volts again.
