Hi Gang!
I have a 1997 Z28 with 82K miles on the clock!
Parts Replaced: Optispark, Plugs and wires, EGR valve, IAT sensor, Map Sensor. Cleaned Throttle Body and replace gaskets, New Fuel Pump and Gas Filter. All Parts AC Delco!
No Codes in PCM
Here is some Data Pulled from PCM while car was Idling!
Fuel Cell 16
Long Term Fuel Trim 133Long Term Fuel Trim Right131
Engine Coolant Temp. 175Deg
Map Sensor 27.28HG
IAC Counts 11
Short Term Fuel Left 127Short Term Fuel Left 126
Knock 26 Knock Retard Timming Odegrees
IAT Temp 123
Mass Air Flow 6Gr per second
Map Volts 1.14
O2 Sensors were switching continously from 89 to 900
on both Left and Right sides. However, I noticed that the right side didn't switch as much in the up range of 700-800 milivolts like the left side did.
Spark advance was 26-28 degrees
TPS Volts .65 TPS% =0
Sorry to be so long but I have been tracking this problem for over a year now!
Thanks Lee!
No Codes in PCM
Fuel Cell 16
Map Sensor 27.28HG
IAC Counts 11
IAT Temp 123
Map Volts 1.14
Thanks Lee!
