I CANNOT get my valves adjusted. NSA Pro Mag 1/6, 14011051 GM Guideplates, Comp R lifters.
I've tried zero lash, rockers were jumping off the valve stems (SA rockers at the time). I've tried 1/16, no dice. 1/8 turn, no dice. I just got done setting them to 1/4 turn past zero lash, and they're still making a hellacious clacking and snapping sound!!!!
I'm doing each cylinder at TDC by firing order. I've tried feeling for zero lash by the moving the pushrod up/down method, by the spinning method, and I've even gone as far as calling zero lash when the pushrod starts to get hard to spin instead of just starting to feel drag.
On cylinder number three for some reason when I spin the retaining nut down it doesn't resist as much with the rest of the set, but the lifters are NOT collapsed.
I can't really do a dynamic setting because of my OVC wires, as I'd be needing replacements real quick!
How quiet is a NSA/Guideplated setup supposed to be??
Anyone got any ideas???? This is driving me NUTS!!!!!
