I'm getting a magnaflow catback exhaust system. How do I remove the cats and run this system? Do they make a pipe to go from the header to the Y pipe? How exactly is this done? Any pictures?
removing cats?
removing cats?
Tags: None
Is a "cat back" system not ment to be put on from the cats back? without removing the cats? and arent us polution laws very tight about that stuff? thought you couldn't take off the cats down there.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Yes, a cat back should go from the catalytic converter back to the tail pipe. You would have to buy a "off road" y-pipe to get rid of your cats or weld a pipe inplace of them.97 SS #C007
Polo Green w/ tan leather A4
There are a few counties/states that do not require emisions testing.Originally posted by DeWynterIs a "cat back" system not ment to be put on from the cats back? without removing the cats? and arent us polution laws very tight about that stuff? thought you couldn't take off the cats down there.2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
As has been stated, a cat-back does not replace the cats, it bolts up to the back of the cats. The exhaust system consists of the following parts:
headers or manifolds
y-pipe
cat(s)
Intermidiate pipe
over-the-axle pipe/muffler/tailpipe
In a cat-back system, you get all the pieces listed after the cat(s). You can get headers to replace your manifolds, and a high-flow y-pipe to take the two sides of exhaust down to one, and high-flow cats are also available. As was mentioned, you can get an offroad pipe to replace the cat(s) so your exhaust can dump out before travelling back the intermidiate pipe to the muffler.Dave M
I know there are countries without testing as I live in oneOriginally posted by ryan34There are a few counties/states that do not require emisions testing.
I feel they will probaly start testin in the next 5 years but my province will be the last one to get it, as we have oil refineries that make more in smog in a day than all the cars in the local area make in a year.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
he said counties, not countriesOriginally posted by DeWynterI know there are countries without testing as I live in one
each state in the US is divided into multiple counties....some whole states do not require emissions testing, while in other states, some of the counties do not require testing while others in the same state do. my county does not require emissions testing.
Red '02 Z28 M6 - purchased 6/24/04 with 11,706 miles
CAGS Eliminator
thanx for defense 02z28Originally posted by 02Z28he said counties, not countries
each state in the US is divided into multiple counties....some whole states do not require emissions testing, while in other states, some of the counties do not require testing while others in the same state do. my county does not require emissions testing.2006 Saturn Ion Redline
Sorry I was reading to fast for my own good
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
