Hey guys, I've been messing around with my car lately.....Today I took out the MAF screen, and I'm going to be doing the free ram air mod and buying a K&N filter. It's a 97 T/A. I have also been looking around on the internet on the F-body FAQ. I found three GM Tech Service Bulletins on my car. I've actually been having these three problems. The first one is number B005001. It is the one about the call for rubber isolaters at the bottom of springs to act as a cushion and stop squeeks. The second one is number 474201A. This one is about the metal squeeling noise from the rear on high speed turns. This my car does also...coming from the drivers side rear I believe. It calls for a shim of some sort? I don't really get it. Would a GM dealer know how to fix it? The third one is number 476109. It's the screeching sound from the engine on hard shifts. It is throwing the belt and causing it to screech. What would it take to replace the belt tensioner with an improved one? Should I replace the A/C Pulley and clutch and the belt too? When my a/c clutch ingages is causes a constant clicking sound. Kinda loud. And the air isnt that cold. How much would each of these bulletins run me at the GM dealership. Are these easy jobs? Any help is appreciated. Thanks!
Jason
Jason
As far as the belt goes, you might try pulling off the belt and taking a wire brush to the pulley grooves of all the accessories including the crank pulley. There just might be road film or crud that gas gotten into the pulley crevices and is causing the slip. For some, that cures the problem. That at least is a no cost attempt. If that doesn't work, try a new belt. Some have had luck with a goodyear belt.
