Ok I need a brake job, which brake pads would you guys recommend? Also seems like my starter might be gone soon, any good aftermarket pieces out there? Any input will be greatly appreciated. Thanks .
Which brake pads?
I like the EBC green stuffs, I had those before, now I have a better than oem from summit, forget the name. Good pricing though. I've also used bendix, available from advance auto. Oem pads that are fairly decent. I'm thinking of trying the hawk pads next go around, since its a package deal with cross drilled slotted rotors for less than 500.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
Yes i was looking at Hawks also, but they cost little extra for front and back it will run $120. Can i use hawks in the front and let say non performance like bendix in the back? Also I dont think my rotors have been rafaced or replaced at least not by me, using performance pads would that speed up the wear on them?1993 TA SOLD
It is always a good idea to throw new rotors or have them resurfaced when replacing pads, that way if the rotors are warped it doesn't wear down the pads quicker than they should last. You can put performance pads in the front and non, something like bedix in the back, that's what i've always done. They shouldn't make your rotors wear any faster. That all depends on your braking style.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
