Yesterday I was down on the ground using clay to get some crap off the bottom part of the rear bumper cover when i happened to notice under the car that my differential housing/axle was COVERED with thick gooey axle grease!!! Ugghh All over the bottom of it and some on the rear cover lower part also. I tried to spray it with degreaser and hose it off and it didn't even all come off.
I need to drive it up the ramps so i can get further under it but I'm thinking its the front oil seal since the airflow would push it back over the case. Is that a labor-intensive job? How expensive would that be? Has anyone else ever had this type of leak, is it common on the f-body? It has been about 50k mi since the case was last opened to change the fluid.
