I have a 383 LT1 with a Comp Cams 306 grind cam, ported heads intake. It is 11:1 with 30# injectors and 50psi of fuel pressure. I have a questionable situation happening maybe someone has some input on it. I am seeing BLM's of 108 (extremely rich) below 3000 rpm, my exhaust temp. gauge reads between 1200-1400f with normal driving under these conditions. The car seems to run good and has good throttle response. Also the chrome headers are starting to turn blue from the heat. The PCM is telling me I am rich, but from the exhaust temperature and the header color I am concerned that I may be running lean. Any help would be appreciated.
Thanks,
Brandon
brandonacooper@alltel.net
Thanks,
Brandon
