alrite i need some opinions
  • alrite i need some opinions
    i believe i have an exhaust leak,but i am not sure, before the car is warmed up, when accelerating it sounds raspy, and like a putting kinda exhaust sound, once the car is warmed up, it sounds amazing, could this be either a crack in the mainfold closing when heated, or a gasket? if so is it worth it to fix it, am i loosing power, and should i go ahead and do headers, money is a large issue, but performance and time is too, how much power am i loosing,and wut should i do to tell if it is an exhaust leak?
    1994 firebird formula
    that could be programming.
    you need to start it cold, and get under the hood with a fine spray bottle and squirt and eliminate an exhaust leak on the mainfolds, then work your way under the car and look for the tell tale signs....
    kapish?
      kinda not really
