take a look(wheel hop) and other stuff
  • take a look(wheel hop) and other stuff
    i believe the reverse gear in my rearend is not cut perfect or something, i am not sure if this is normal when u replace your rear ring and pinion or not, but i have wheel hop in reverse, how can i fix this?will subframe connectors help,
    also i noticed my car vibrates alot now, my tires are at about 30 percent tread, and i have had to reseal the bead because of lopw pressure in the tire, could they be off balance they have been on for about a year now, but i take alot of hard corners, and i spin my tires more than i should, i have hurd subframe connectors help in vibrations, but how much, and wut type of tires should i get i have 17 X9 inch wheels,wut all would i get from subframe connectors
    any opinions or comments welcome
    thank you
    1994 firebird formula
    I'm not quite sure I understand what you stated. There is no reverse gear in your rearend. The transmission is what controls that.
    Subframe connectors will help with a lot of things like interior squeaks, vibrations, and improves chassis stiffness. But, it depends on the kind of vibration. When does the vibration take place? At a particular RPM, at high speed, etc.? Vibrations can be caused by a lot of things.
    Engine: 305 TBI (L03)
    Trans: TH700R4
    Mods: Some
    CarDomain Site
      at around 40-60 it vibrates, and i have wheelhop in reverse that is all i no
        How much wheel hop in reverse? Right when you first throw it in and it first engages into gear?
        Traded in: 1998 Z28
          no, when i give it gas, not floored but a lil
            When the word "wheelhop" is used it usually means that the tires are bouncing off the ground slightly under acceleration. Are you trying to do a burnout in reverse or what?
            Reverse gears in the tranny are most always a "straight-cut" gear as opposed to a "helically-cut" gear. This will make them a little whinie and they are not as smooth in engagement with one another as a helically cut gear would be.
            Can you describe in a little more detail what you are experiencing? Also not sure what you are referring to the rear end as far as reverse for?
