The engine is almost stock (ported and polished heads, 0.039" Fel Pro head gaskets). I do not want to upgrade the cam, chain time etc; the stock ones has 55 k miles.
I want to upgrade the next parts but I'm truly confused about which types or brands are better for my street daily car:
* Roller rockers 1.6: non self aligning or self aligning (stock ones are this type,right?)? I don't want to replace the valve covers
* Pushrods: 7/16" or 3/8"? hardened or not
* Guide plates or not? My stock engine has not guide plates, right?. I recall the stock head gaskets had a guide holes, but the Fel Pro has not them.
* Springs: LT4 or another brand?
*New locks and retainers too?..are they necessary?
I don't need a 500 HP engine for street now or in the future.
Thanks to clarify mi mind about this upgrade
Regards
Doc
My car has this mods:White 97 Trans am A4, Ported&Polished OEM heads, 0.039" Fel-Pro Head Gasket,
Air Foil, !TB, K&N FIPK, SLP "2on The Left", Random Tech dual converter Y-Pipe,
March Pulleys Set, LT4KM, 160º Thermo, Fast Chips Reprogramm, B&M Tranny
Cooler, BMR Tower Brace & tubular SFCs, SLP Panhard Bar, SLP-Bilstein Shocks,
Spohn Adjustable Lower Control Arms,Torque arm & Relocation Brackets,Prothane polyurethane bushings & end links,GM 1LE Springs & Sway Bars (32mm front & 21 mm rear) kit, GM 1LE aluminium DS, Russel&Earl's 5 SS braided brake lines, KVR X-Drilled & plated Rotors, Raybestos ceramic brake pads, Bridgestone Potenza RE730, Hella H4 Euro headlights with 100/80 Xenon bulbs, Deutsche Xenon fog lamp bulbs,GM silver plastic wheel lug nut covers, Black Bat-Decals, GTS Solarwing II, Ken Collings' Fog Light lens covers, & Joe Bowen's Fog Light mesh covers
Regards
Doc
