what do you guys think of ATI prochargers?
  • what do you guys think of ATI prochargers?
    so i am thinking about putting the ATI p600b, or p-1sc looking to go with 14psi, and have some fun. any one out there have this one. it will also be the twin intercooled kit. along with a motor built towards it. 9.5 compression, mild low/no overlap cam, total seal rings, forged pistons, and maybe some AFR 190cc heads.
    what are your thoughts on exhaust? long or short tube headers, flowmaster or loud mouth?
    past rides:
    1994 Z28 A4 totaled
    If you are truly looking to use around 14 psi I would go with the D-1SC. To maintain 14 psi out of the P-1SC would be very hard on it. Not sure what you mean by a no overlap cam? It is wise to decrease the amount of overlap by way of a numerically higher LSA (lobe separation angle) in boosted apps, but you will always need a certain amount of overlap to provide a scavenging effect for the new a/f charge to be helped in. If you asked for someone to grind you a cam with enough LSA to completely separate the two VE's, they would look at you like you were crazy.
    The total seal rings were a good idea on paper, but just to let you know through the grapevine I've heard a lot of ring failure stories from Total Seal ring sets. A slight gap (.007-.015) in the top ring (compression ring) is actually a good thing. The combustion event itself needs an ever so slight bit of a dynamic compression leak to prevent ring butting. Especially on a boosted motor. Go with something like the JE Hellfire's or even the Speed Pro's. The gap is not so significant on the second ring or even less so on the 3 piece oil control ring pack.
