Well after I called the shop that was doing the work they said it's still making the same noise and not getting pressure. The mechanic I talked to said it sounds like a spun bearing. What else internally could cause me to have no pressure and a "tapping" noise?
Not the oil pump
A spun bearing most likely.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
