The cooling system was flushed last summer when a new water pump was installed. The problem is, it's running hot. Climbing hills on a trip yesterday, I had to take it easy in order that the temperature not run above about the 225 degree mark.
RangerBob mentioned a 160 degree thermostat option. What exactly does this thermostat do? Do colder thermostats simply just open sooner? Or are colder thermostats less restrictive when open, thereby allowing for coolant to flow through the system more efficiently?
Thanks,
Martin
Utah
Stock 94 TA
Thanks,
Martin
Utah
Stock 94 TA
