The Hotchkis Performance Swaybar kit 1 7/16" hollow front and 1" rear was what i was looking at, the question is when the sway bar is hollow does it effect the stiffness of the bar?
Sway bars??
Stiffness varies with the wall thickness, and diameter (and length). A hollow bar of a given material isn't as stiff as a solid bar, but there is a huge weight penalty for a solid bar. Usually a hollow bar will be bigger diameter (which is a major factor), and better material, and they have to design it with a diameter to wall thickness of less than 50:1 to keep from having a catastrophic failure from dents or dimples (like on a beer can).
I forget how to do the math, but you can take a 1-1/2" tube and a 1-3/8" tube of the same wall thickness & length and the 1-1/2" tube will have 1/2 the deflection of the smaller 1-3/8" tube! Thats a tube that's only 9% bigger so you can see that a little extra diameter buys you a lot of stiffness.
