Whenever I start my car cold and rev it up to about 3000 RPMs it will backfire. I just put my SLP loudmouth on about a week ago. The loudmouth isn't the cause of it because it did it with the stock exhaust too but it's just more noticable without a muffler. Any ideas of what's wrong. I'm leaning towards the idea that my opti-spark might be starting to go bad after 94,000 miles.
Why does my car backfire?
It's a couple small popping sounds and then a really loud pop. I'm not sure what's the difference between that really loud pop and a backfire?
1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
Is it only for the first few minutes? Does it do it after its warmed up? If its only at first its because your in either closed or open loop I forget which is which. That is when the car is not using the O2's and is just using a default setting. Whenever your warmed up and get into either open or closed loop (the opposite of what it is warming up) it should stop. My brothers 99 Z28 with 30k miles on it even does that.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
With stock manifolds, and the design of the y-pipe type system on our f-bodies, it is common for the exhaust to pop like you described.
I have the same issue. I have two bullet mufflers on what is otherwise a straight exhaust, and I hear it too, mostly in open loop. You don't hear it as much through stock exhaust, but when that muffler is gone, it really shows up. Completely normal."No, officer, that bottle is my onboard Halon system"
ah, the joys of having a remote start option on your car alarm! start it up about 5 mins before you go anywhere, and viola! no more popping!
i've noticed that on my car too when i forget the remote start and it first starts up....usually notice it when i'm shifting
Red '02 Z28 M6 - purchased 6/24/04 with 11,706 miles
CAGS Eliminator
