you osaid with my mods i could not benifit from a 58mm throttle body, what kind of mods would i need to benifit from that?
ken, question about big throttle bodies
Just a reference point or two.... my 381ci stroker, turning in excess of 7,000rpm and making 500HP was only using 77% of the flow capacity of the 58mm Holley throttle body. That is confirmed with engine dyno testing. GM puts the same 48mm TB as the LT1 on their RamJet 502ci/502HP crate engine.
Here a link to an interesting thread where someone dyno's a 48mm vs. a 58mm TB on a realtively stock setup, and lost HP.
48mm vs 58mm TB DynoFred
fred said it best my friend.
untill you do heads, cam..and all that stuff.... stay TB O.E.
Plus, with the 58mm TB you would need to enlarge the openings on the stock intake to match the 58mm, they are only 52mm.69 Z28 with JL8 factory 4 wheel disc brakes, crossram, transistor ignition, radio delete, heater delete - being restored
2000 SS Camaro daily beater
could i benifit from a 52mm?
Do you get traction with the power you already have? If not maybe you could spend the $300 on suspension or chassis upgrades. A lot of guys let the engine get ahead of the chassis setup (see my 60' time ). In my case, I need to get traction before any more go fast mods... Just a suggestion to help you have a more balanced setup.
Do you get traction with the power you already have? If not maybe you could spend the $300 on suspension or chassis upgrades. A lot of guys let the engine get ahead of the chassis setup.'77 K5 rock-crawler project
Thomas Jefferson
Just to throw another view into the mix
I bought a 58mm AS&M TB before I started this 355 build-up I'm currently undergoing, but I did have a LT4 setup at the time and did not loose any HP but the gains were minimal.
NOW, I did know that I would be going bigger and badder than the LT4 had to offer so it was room for growth to me and I have to be honest, the darn thing just looks SO nice in there, LOL.
So if you plan on going with aftermarket heads and a nasty bump stick...then knock yourself out...if you don't plan on going more radical than a LT4 setup...stick with the stocker or no larger than a 52mm, the mod money could be better spent else where.
Just my .02
KnightFire
