I have a 1994 Formula Firebird. The other day i was driving normal and slowing down for a stop light when all of the sudden my car backfires REALLY LOUD. Then my car loses power, rpms drop really low and then dies. I try to start it and it wont start. Turns over and everything, but just wont start. Before this in like second gear it would back fire sometimes and lose power for a little bit and kinda have trouble starting. Well in the dark when i look at the ignition module, i see blue sparks coming off of the water pump.
Also when i took a plug wire off and put a plug in it and ground it, i dont get spark. I take the wire that runs from the ignition module off of the coil and i get spark. Im thinking its the optispark even though it had been replace once in june then again in august cause it was fault i guess. Any suggestions of how i can check if the optispark is fualt. thanks a million!!!
