Originally posted by azkkn
Even when using the Total Seal rings it is only the second ring that is different from a standard setup. The compression ring (top) ring and oil control ring sets are the same. Well kinda.
The issue with total seals is that they attempt to use the second ring as the compression ring when it is normally desgined to function as basically an oil scraper. When you use the second ring as a compression ring it creates a high pressure area during the compression stroke between the first and second ring. That pressure unloads the top ring and as a result high rpm flutter will occur and significant power loss can be a result as well... Not to mention cylinder wall scarring.
Then you must use a high tension oil control ring set because of the lack of the second ring doing it's intended job as an oil scraper. That also will cause power loss.
Additionally Total Seal claims to reduce blowby. Unfortunately they only performed their leakdown tests without the motor running. How convenient.
Lots of f-body speed shops tried the Total Seals when they first got popular and found out that they were basically crap.
