after the install of headers and off road pipe are the oxygen sensors imparative to the car being able to run correctly?
off road y pipe and o2 sim question
AMF RACING: Friends don't let friends drive junk
01 black ss #0966
lou's short stick, slp lid and cold air, smooth bellow, centerforce, loudmouth, 3 in. y pipe, flowtech long tubes, BMR STB, SLP 4.10's, polished zr-1s, MSD wires, T-6 plugs, and upcoming goodies....Tee-HeeTags: None
Without the sims (or programming the after-cat sensors out of the PCM) you will be staring at the SES light all the time. The performance of the car won't be affected, but that means you will never know when there is a "real problem" also causing the SES light.Fred
thanks, what about the pre cat sensors, there is no bung for them are they needed?
01 black ss #0966
The pre-cat oxygen sensors are needed. They basically monitor how the engine's running. The after-cat oxygen sensors just monitor the efficiency of the cats, so you don't need those if you gut the cat or remove them.1991 Chevy Camaro RS (Is it plum or purple?)
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
