Hello everyone! I did some searching on the forum but could only find a few bits of information that could give me some insight on the questions I have. I an the owner of an 84’ Trans Am and I wanted to do some suspension upgrades to it while I rebuild the front end. I have installed a Moser Ford 9” along with a TCI Streetfighter 700-R4. The rear springs/shocks are Eibach Pro Springs and Monroe Sensitrac shocks. I have read that the stamped lower control arms, panhard bar, torque arm, and upper & lower A-arms are relatively weak. I also was curious about sway bar kits. I am near-clueless on this after trying to sift through a sea of chrome moly tubular thingamajigs and what not. Here of some of the things I have tracked down. Globular West, I believe, makes tubular A-arms for the 3rd gens.
http://www.jegs.com/cgi-bin/ncommerc...07&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...67&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...79&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...69&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...05&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...43&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...90&prmenbr=361
http://www.fasttoys.net/8292fbodysusp.html
What –IS- all this stuff?? I am confused as to what the differences are between all of these products, and brands. Yeesh. I know the adjustable lower control arms are sort of useless and can only benefit you if you want to use taller tires or something like that. But what is the difference between boxed and tubular. What are the pros and cons of each? What is the benefit of going with tubular A-arms and are they worth the money? The subframe connectors I know I am going to need because the motor I plan to install will hopefully push 450bhp and hopefully similar torque stats. Right now I am looking to upgrade the suspension to a tight cornering system that will be able to handle a good deal of power and actually keep the tires planted. The tubular panhard bars are supposed to help keep the rear end aligned properly under acceleration. I have heard a –lot- of good things about LCA relocating brackets in helping reduce wheel hop. Is an adjustable torque arm any use on the street? How will it drive in wet conditions with these upgrades? This is a daily driver, but I loved the effects the springs and bushings had on the rear end. Much more control and handling!! Any wisdom or criticism is welcomed!! Thanks!
____
1984 Anniversary Trans Am – Stock 350, Moser Ford 9”, TCI Streetfighter 700-R4, true dual 2.5” exhaust. 16x8 Formula wheels w/ Firehawk SZ EP50 tires.
____
