Can you give some more information? Does it do this all the time or only when cold? Auto or stick? The ignition module is out...that would cause a misfire or no start. It could be a sticking throttle. Check the position of the butterfly while its idling high. Just feel where the lever that the throttle cable connects to is and see if you can close it by hand. If so, sticky throttle. If not, check to see if your car is burning rich or not. Probably the best thing is see what the computer is doing. Knowing such things as what the BLMs are and what the injector pulse widths are will help greatly in pinpointing the problem. Keep me posted. Take care and good luck.
