I have had an oil leak that I took my 95 Camaro V6 to the shop for this morning. They called and informed me it appears to be the rear main seal leaking. The stinker is, I just had a 94 V6 engine dropped into this thing in January.
Anyway, assuming it is the rear main seal (they are doing a dye in the oil test), is there ANYTHING else I should have them do while they are tearing this thing apart to fix it? I assume they will have to drop the engine?
Anyone have a ballpark cost for such a thing? I'm figuring at least $800 if not more.
I suppose some shops get that much, but that is a 3 hour job, tops. That would even include a sandwich break.
Granted, the cooling system must be drained so there will be the cost of coolant as well. Labor on an alternator should be cheap. I've done it on my 3.8 in a ½ hour. So the major cost of the alternator is the cost of the part. As far as what caused the leak? Don't know unless is was a poor install from the beginning. The LT-1s had the notorious intake oil leak, but that was due to the EGR pipe causing an overheat of the rear edge of the manifold. The 3.4 is a totally different animal.
