I'm sorry to post this again, but I really want to make sure that you guys see this question here. I am really confused by the information in this post... how exactly could open headers / straight pipes result in less torque?
http://www.f-body.com/index.html/sho...=&threadid=720
There is a slight anti reversion effect created by an after header system as well. As a muffler adds restriction as the gas flows toward it within the exhaust pipe, it also restricts the flow in the opposit direction should the gas try to reverse. The theory can be demostrated by a simple straw and a glass of water. Take a half full glass of water and insert the straw, gently blow a small amount of air into the straw, but not enough to blow the air out of the straw and into the glass. You'll see the water level within the straw fall below the level of water in the glass. So far you are seeing an effect of "backpressure" that the water in the glass is exerting on the straw. Suddenly release the air pressure from the straw and the water rises above the water level of the glass and settles back down. Notice that the water doesn't shoot out the top of the straw. It won't because the same force that "pushed" back against the air you were blowing into the straw, prevented the water from going up and out the straw when you released the air pressure. Usually this effect in an exhaust system is reduced exponentially as more positive pressure is produced from a WOT exhaust event. There is some benefit using this principle in cruise situations and mild throttle openings.
