LT1 head removal: headers have to come all the way out?
  • LT1 head removal: headers have to come all the way out?
    I am about to pull the heads and was wondering if the headers can be unbolted and left in place. I dont' even know if I can get to all the head bolts with them in. Just didn't want to do the whole y-pipe, steering linkage, etc.
    Also, I have never been able to remove my knock sensor (not from a lack of trying). If I only drain the block on the drivers side, will coolant go everywhere when I remove the passenger side head?
    Thanks in advance
    Sean
    Thanks in advance
    Sean
    You can most likely get away with leaving the headers unbolted and off to the side. There is a total of 8 bolt holes on the "outer" exhaust side of the head.
      Kev's right, but you might have to undo the y pipe just to drop the headers down far enough to be out of the way. The coolant can be sucked out of the block from the water pump with a wet vac.
