I had the dealer replace my Smog Pump under recall today. I also have two other codes settin off the service engine light now though. One is the EGR. The guy said that it is probably caused by the lack of backpressure because I have no cats. He said if the EGR was screwed up I would have a hesitation at idle more than likely. After I get my car out and going and warmed up, when I stop at a stop light, the car will kinda stutter a couple times off and on, I told him this and he said it might be the EGR is actually screwed up then. Has the lack of cats ever screwed up anyone elses EGR on there T/A or camaro? I am going to call Dal and see how much he charges for the EGR and solenoid. How big of job is it to replace this gadget?
Also another code is for the bank 1 sensor 1 O2 sensor. That should be fairly easy to replace wouldnt it be? Probably have to spray a lot of penetrant around it though wouldnt I?
Well any thoughts would be great.
Thanks
Jason
Thanks
Jason
If it is bad, the o2 sensor will most likely require a penetrant to get it loose. I prefer PBlaster. That is great stuff. If it is stubborn, you might need to start the car and get a little heat into the sensor to make it easier to remove. There is a specialty tool that is very helpful. It is an o2 sensor socket. It looks almost like a spark plug socket with one side carved out to permit the sensor wire to not be destroyed or pinched. Once you get the faulty sensor out, be sure to clean the area really well with alcohol. This step is what 99% of the techs don't do. The chemicals in the penetrant can kill an o2 sensor quickly. Even residual stuff left behind can shorten the new sensor's life. It might not kill it right away, but it can shorten the life considerably. A little dab of anti sieze on the threads (keeping it away from the sensor bulb) will help the next time you have to change it.
