I just finished the rocker/spring/lifter/pushrod install, and used the engine running method to adjust the rockers. Now I'm seeing knock retard when I'm driving??? I already put the LT4 module in a while back. Could loose/tight valves make this problem?
BTW, here's what I did to adjust...tightened (barely snug) the nut on each rocker at TDC. Then, I started the engine, and went 1 by 1 tightening each rocker, using a stethescope, until the most obvious loud clanking was gone. Then I tightened it more - 1/2 turn for the preload on the lifters, and finally tightened the locks. I'm using the OEM Comp Cams lifter replacements - not the COMP Rs.
Oh yea, the BLMs are still high on the driver's side
I'm completely out of ideas. Thanks for any input.
