My 4th Gen is starting to get a lil shaky and not as tight as when I bought it. I have put new tires on. Is there somethign I can do to improve the ride quality and suspension specifically? My friend was telling me about shocks and struts and springs. Would that help? What do you guys recommend for driving it daily on street? Brandwise and sizes? What are my options? Thanks in advance for any help
Suspension
If you're looking to stiffen the frame, I'd go with a set of subframe connectors...'99 T/A WS6 w/ Borla cat-back, K&N, SLP SFC, SLP STB, BMR boxed LCA's, BMR Adj. torque arm, BMR panhard rod, BMR springs, and Short Stick
(a list I know, but if I don't put it here, I'll never write it down anywhere else)
Sub-frame connectors and strut tower brace my bird has 43K and these two items improved the car 150% its the best thing I have done to my carI have Don Goetz SFC and would highly recommend them
1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
I've put SFC on my Camaro and my old Mustang. I have been amazed at the difference it made on both cars. These are the ones I used on my Camaro http://www.bmrfabrication.com/F-body...frameconnector . I used the boxed ones. They are bigtime overkill. It really helped eliminate a lot of "noises" in the car.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Hello,
We have 10% off sale going on right now on our subframe connectors
http://www.f-body.com/forum/showthread.php?t=7465
Lifetime warranty of the craftsmanship
Regards,
Ryan
New shocks for a 97 with only 35k miles???
I'm on my originals and my car handles fine with the stock suspension. I have almost 120,000 miles on it. The only mods for handling that I do have are subframe connectors and a strut tower brace...Firestone Firehawks help too. I'm finding it hard to believe you need new shocks...what do you mean when you say "not as tight" or shaky?Joe K.
'11 BMW 328i
'10 Matrix S AWD
Subframe connectors should be the first chasis/suspension mod anyone does.
I recommend weld on.
I wish I had some. It is on my list of things to do.Tracy
My Z is a 1995 hardtop and I installed SFC's a couple years ago and I could even notice a diff (being a hardtop). Since then I have installed SLP's Level 1 suspension pkg including Bilstein shocks, Eibach springs, 1LE sway bars and its very tight for a 9 year old car with about 100K miles on it.95 Z28, A4, 3.23's and some other stuff....
Originally posted by lt14mlaok im going to put an order through for some SFC's and panhard bars. Do you guys reccommend the adjustable panhards as opposed to the non-adjustable ones and why? I need 2 panhard bars right?
You might be confusing it with swaybars. There are 2 swaybars, one front and 1 rear. Installing bigger ones with stiffer bushings will improve handling considerably.
First I'd do the SFC's, then the swaybars.Tracy
Heres a pic of a Panhard bar installed, the panhard bar is the longer sliver bar running across the car next to the muffler.
http://www.umiperformance.com/ebay/images/2020g.jpg
Hope that helps!
Ryan
