Does anyone know the stock compression on an 95 LT-1? I'm considering a turbo for my car. I only wanna run about 7lbs. I have a 52mm throttle body and stock 24lb injectors. I have bosch in tank 255 pump. The rest of my mods are in my sig. I'm just getting sick of spending $35 dollars on nitrous refills. I will still run nitrous, but only a 75 or 100 shot. I don't know that much about turbos, so I have the following questions:
To be honest, I don't really know what the compression is. It is atleast 10:1 or 10:5. I'm not the most knowledgable person when it comes to compression, so I can't tell you much either about the pistons or the rod length. The heads are afr 190 and the chamber size is 56cc. The can I am running is a 224/224 dur with a .554/.554 life w/ the 1.6 rockers. I have a moser rear with 4:10 gears The crank is also stock. Iwould like to be in the 450-500 rwhp range without the nitrous. I say 7 lbs because I'm assuming I can get away with the stock injectors. I had the computer programmed by psmforless, but tuned by a local guy. Basically I'm looking at the rear mount turbo from ststurbos.com. Also, I've decided to do a turbo because I'm looking for more power than what I got on the street without having to bring the bottle along.
1.Are my injectors an ok size with a 100 shot and turbo? I have a direct port kit, so that elimates the need for bigger injectors on the nitrous side
2. Is my 52mm throttle body big enough?
3.Computer reprogramming?
4. Clutch recomendations? spec stage 3 or 4?
5. How do I check my current compression? I think it is 10.5 The block is bored .040 over and I have JE forged pistions and eforged eagle rods.
6. Am I insane for even thinking about this?
Thanks guys!
Thanks guys!
