Ok, I'm going to see if I can get this figured out once and for all. The ABS is really starting to tick me off. Here's the background, for those who missed it:
When I bought the car, the prev. owner said that the ABS has been acting up since he took it to a concert. Said when he came back afterwards, the dirt lot had been turned to mud (why he would park it in the dirt is beyond me). Ever since, the ABS would either go to INOP or would start pulsing the brakes when slowing to a stop...at around 15 the front brakes would release (rears are fine) then grab again about 5. He had the stealership replace the front right speed sensor and said it went away, but came back after a short period of time (few weeks, couple months, something like that). Well, once I bought the car, that was my first endeavour. I bought Joe's hubs (Joe 1320 that is) and put them on. At first, it was fine. But, later that day it went back to the same old thing. I've even had it pulse the brakes at 55 MPH!!! I've swapped the front right sensor 2 times now and still nothing. I replace the jumper harness for the front right sensor and nothing. So, I'm down to the second harness that the jumper connects to and the Brake Control Module.
So, here's my questions to pose. 1) Which is it more likely to be, or should I consider doing both? 2) If its the harness, is it a main harness that connects the BCM to multiple points (sensors and such)? If so, how much of a PITA would that be to do or should I let a shop do it? 3) If its the BCM, is it as easy as it looks to swap it? 4) What are the part numbers for these pieces? I'm pretty sure I've got the BCM # around, but the harness I cannot find. Thanks a bunch guys and have a good rest of the weekend.
