Does anyone know if Lamborghini door kits can be put on F-Bodies?
Lamborghini Door kits
i'm assuming you mean some type of kit that will convert the standard F-Bod doors to the Lambo-style swing-up type doors? i know it can be done, cause i have seen some pics of a few of them, but i'm not sure if there's a "kit" per se.....
Red '02 Z28 M6 - purchased 6/24/04 with 11,706 miles
CAGS Eliminator
CAGS Eliminator
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7928603543&fromMakeTra ck=true
I found this one-it says that it will work for a 350 lb door
Coming soon: A Firebird graphic opposite the Camaro graphic-
The f-body door doesnt have any frame at the top of door, just window. This would be hard to work around.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
