How much HP/TQ can the stock bottom end of an LT1 take before it blows in a daily driver situtation?
Strength of the stock bottom end of an LT1?
2-Bolt or 4 bolt main? Read this article: http://www.automotiverebuilder.com/ar/ar99928.htm
If I understand it correctly it is basically nearly 450 HP.
Jared--- Jared ---
/ 95 Z28 Camaro (Mystic Teal) / LT1 (+.030) / LT4 Hot Cam / 52mm BBK TB / Moroso CAI / 4LE60 + transgo shift kit / 2200-2500 Stall Converter / PCMforless Custom Tune / Edelbrock TES Headers /
Originally posted by jbs4radio2-Bolt or 4 bolt main? Read this article: http://www.automotiverebuilder.com/ar/ar99928.htm
Jared1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
Originally posted by Squat13They never made a STOCK 4-bolt Main LT1 only 2-bolts. All 4-bolts are aftermarket blocks or LT4
The bottom end of the LT1 differs in the use of powder metallurgy rods, introduced in the Corvettes on 1994 and a rolling change on the F-Bodys in 94/95. The rods are rated at 450HP, but the only two documented cases I have seen of a PM rod failure were on "power adder" setups, at about the 600HP level. I don't think you would have any problem taking the stock rotating assembly to 500-550HP, as long as you keep the rev's down.
The block itself has been shown to reliably withstand 1,200-1,300HP, at least in the factory straight 4-bolt configuration, or with a splayed 4-bolt conversion.Fred
Originally posted by Squat13sorry I ment factory replacment. Do they even make an aftermarket LT1 block?Fred
Originally posted by InjuneerNo aftermarkets were ever made. You could buy a factory LT1 block up until they stopped making them in late 1998 or early 1999. All of these replacement blocks were 4-bolt blocks. I tried to find one at the end of 1999, and it was impossible to find a new one. I think Burt Chevrolet in Denver found a stockpile of LT1 "marine" engine short blocks a couple years back, and was selling those, but otherwise there are no longer any "new" blocks available.1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
