Was looking through the July 2003 issue of Car & Driver.... has the Ferrari Enzo on the cover. The Enzo 650HP/485lb-ft V12 comes with the Shell Helix 10W-60 synthetic from the factory. The Warranty requires that you use ONLY that oil, and is takes 12Qt for a change.... = $720 just for the oil. If you fail to use it, the warranty is void, and you would have to replace the engine at your own cost.... and that's ~$200,000.
Also an interesting teaser on the Bugatti EB16.4 Veyron..... QUAD turbo-charged and intercooled DOHC 64-valve 8.0Liter W-16, 7-speed sequential manual tranny, 4-wheel drive, variable valve timing, direct injection, 987HP/922lb-ft.
