spark plugs on a 3.8
  • spark plugs on a 3.8
    got 4 of them done, but two i couldn't get. one on either side of the block on the underside. i could get the plug wire off but there wasn't enough space to get my spark plug socket wrence on it to get the plug out, and i couldn't do it with my hand. any suggestions? this was from under the engine
    get a plug socket with a hex shaped end that you can put a regular wrench on? not sure if you tried that or not
      Spark-Plug Socket, Modified to work with headers (1)
      In order to make spark plug removal a little easier in the crowded F-car engine compartment; SLP has developed this modified spark plug socket. Cut down to fit into extremely tight areas; the socket has had the square drive removed to allow the plug to protrude. The socket is turned using an open or box end wrench on the hex base.
      SLP part 30102 $19.95
      SLP link
      99 Silver Z28 A4, T tops, ZR-1 wheels (SOLD)
