I own a 95 Trans Am,6spd.I recently installed 4.10 gears,they made a huge difference but between 80-100 mph i am getting a driveshaft vibration.It is felt more on decelleration that accelleration but it is pretty moderate.I just assumed it was due to the shaft turning the higher rpms .I have checked the car and found no problems, nothing loose, u joints good, all seems well, and at normal speeds i get no vibration. If anyone has any ideas let me know.
Thanks
Thanks
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.
