Im not going to do this because i dont wanna blow any money right now, so this is like a what if question. How much power would a stock LT1 that u put a 383 stroker kit and LT4 upgrade kit have.
How Much Power
It would greatly depend on the extent of the cylinder head porting and how big of a cam you choose. Without knowing any specifics as to your goals, most NA LT4 setups will produce anywhere from 390-450+ RWHP.Originally posted by 96z28Im not going to do this because i dont wanna blow any money right now, so this is like a what if question. How much power would a stock LT1 that u put a 383 stroker kit and LT4 upgrade kit have.
Heres a link to my dyno results. My engine specs are in my sig. Its a very mild cam and only a mild port job on the heads. Keep in mind, theres a bit of timing pulled from the programming for the nitrous, so theres more power there if I wanted to run N/A all the time. And this is a mustang dyno, notoriously very conservative in their results.......
http://www.f-body.com/forum/showthre...highlight=dyno96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
