how much does a gear change and everything i need included cost usually to get done. Any figures would be appreciated. I called the local trans shop and they said it could be as high as 1500. Im thinking GOD ****! he said that was only if alot of thigns were wrong to begin with. I just want to get an idea so when i do get this done i know im not getting ripped off.
gear change quote
Originally posted by lt14mlahow much does a gear change and everything i need included cost usually to get done. Any figures would be appreciated. I called the local trans shop and they said it could be as high as 1500. Im thinking GOD ****! he said that was only if alot of thigns were wrong to begin with. I just want to get an idea so when i do get this done i know im not getting ripped off.
So roughly $550 should be all that you should spend. Do some calling around... you are sure to find someone experienced as well as reasonable.
3.42 wouldn't give much performance gain over the 3.23 already in the car. It might be a good alternative to the 2.73 cars. However, I think a 3.42 rear in an auto would be ideal if you're looking for a little more performance but want to keep the good fuel economy and high top speed. 3.73's always seemed a little too steep to me, but I do A LOT of highway travel.Dave M
$200 gm motive gears
$50 install kit
$ 3 series carrier $100
$200 labor
$550 = total
eddie 95 Z28 A4 " love my 3.73's"
When I had thre rear 4.56 gears done in my Tahoe at a local driveline shop they only charged me $350 for parts, labor, and gear lube. The front 4.56's cost me a little more to the nature of the front differential.
GM motives on mine for 3 almost years and no whine
one of the best gears you can get...
eddie1995 Z28 A4, SCC Ultra Z Hood with Air box/K&N filter, Granatelli Maf Sensor/Fernco bellow/Hotchkis STB/white face gauges/LT4 Knock module/March pullies/160* stat without Hypertech Tunning/Borla 3" y-pipe/HI Flo 3" cat/SLP Loudmouth/GM Motive 3.73's + TA rear end girdle/Afs ZR1's silver painted with polished lip 17x9.5 front & 17x11 out back/98 tail light's/BMR SFC's/spohn Lca's/spohn relo brackets & spohn adj. panhard rod " coated mid lenght pacesetters headers + 1.6rr + custom pc tuning going on soon hopefully "
Remember to figure in the cost of the PCM recalibration......that another 100 bucks. Might as well get it tuned for max performance if youre sending it out.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
11.6 @ 123mph (1.6 60' - getting there)
Originally posted by N20LT4BirdRemember to figure in the cost of the PCM recalibration......that another 100 bucks. Might as well get it tuned for max performance if youre sending it out.
Good point!
you think that's bad
I went around tonight to a couple of the transmission shops in Billings, Montana and one place told me it would be about $1,200 to change my rear end gears and the other place told me that it would be between $2k and $3k. All i was thinking the whole time is "are these people crazy". I'm gonna do some calling around here in the next couple days for a few more quotes but if i can't find anybody cheaper than $600 i would just rather do it myself!1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
1200 is pretty steep, but it depends on the area youre in. If no one does high performance drivetrain stuff in the area, than those that do raise the price. At my Dad's trans shop, we get about 900 including the gears, set-up kit, labor, fluid, and PCM reprogramming. That a good buck, but our customers pay it, knowing they are done right and we back up our work.
If youve never done a gear set yourself, I would advise against it unless you have someone experienced helping you. Setting up the backlash and preload AND still coming up with a nice mesh pattern is an art. Not to mention you need a good set of calipers or a micrometer, dial indicator, an inch/lb and ft/lb torque wrench. If its not right, you will be sorry that you messed with it. Alot of us live with a bit of whine, depending on the gears we install, but you could chew up a set of gears or bearings if they are not installed right.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
