We are now selling/installing the complete line of STS turbos!
The patented STS(tm) turbo system is the only remote mounted turbo system on the market. Mounting the turbo system remotely has several key advantages, including increased performance, better gas mileage and a short install time.
Most components under the hood of today's vehicles were not designed to operate with extremely high under hood temperatures. In order to place a turbo in an already overcrowded engine compartment it is necessary to do a lot more than just make some room for the turbo itself.
By mounting the turbo remote under the vehicle, STS has eliminated the heat problem. A remote mounted turbo runs cooler, with no additional lag and requires no major modifications to your vehicle.
The basic systems provide ~5 psi of boost, but with additional tuning and turbo upgrades the systems can produce near 20 psi of boost.
Each STS(tm) Turbo System includes all the parts you need to install the turbo on your vehicle. The installation manual includes full color photographs that walk you through each part of the installation.
Garrett Turbo
TiAL Wastegate
K&N Air filter and PreCharger
Turbo Oiling System
HPC coated intake tubing
HPC coating exhaust tubing
Electrical harness
PCV System
Silicon connectors, clamps and fittings
Return oil cap
Full color, step-by-step instruction manual
1 year parts warranty
More details can be seen on our website. We are offering discounts for kits that are ordered by next Thursday, November 18th and are accepting appointments for installations after that date. That will give us enough time to get settled at the new location.
in this pic, it looks like it's being covered....
) with intercooler, gt-70 turbo, going to run 14psi on the street, he only has dyno #'s up to 10 as the spring with the kit is only up to 4lbs.. (but he can get 14 on the street- has to do with air flow) withthe 10lb spring, it will spool up to 10 easily, and get to the 14 psi on the dyno
Maybe next summer.
correct?
