My question is this, I have a 1970 350 from a 1970 Corvette that has been built to a 383. I want to replace the stock Oil pan with a Chrome one. Are all SBC oil pans the same dimensions or am I to be looking for a specific one to fit in my Formula. I realize I need one with the dipstick on the drivers side But I cant seem to find a reference to different ones on different vehicles.
Oil Pan Question for Gen I SBC
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Tags: None
You need one that fits with the crossmember for your car I'm not sure if the generic ones are right for that. you might be able to tell if you can see one in person - Those chrome ones are often made off shore (China) and have questionable or bad quality. Get a nice Canton, or a Milodon or Moroso which has good baffling and get a good windage tray.
Like Kev mentioned, you will have to make sure the pan is specific to your chassis. It will have to clear the factory k-member, steering components, and exhaust.
I would also steer clear of the stamped chrome pans. They are notorious for leaking due to their inherant structural weakness which allows them to flex and provide proper gasket seating.
Canton, Milodon, Moroso, Summit, Jegs, and SDPC all make good oil pans for all SBC generations. And they will also free up about 7-15 fly HP depending on your motor.
Originally posted by fastTA
....Canton, Milodon, Moroso, Summit, Jegs, and SDPC all make good oil pans for all SBC generations. And they will also free up about 7-15 fly HP depending on your motor.1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
