There has been a ton of debate about this ...I removed mine and the throttle response seems better allthough it does seem to idle a little harder ...but overall it was good for my car ...one word of caution be sure to run a good air filter that seals to the air box.
1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
I took mine out and noticed slightly better throttle response, and it doenst idle rougher or anything. Use a good air filter, keep everything sealed up, and you should be good to go
I don't notice too much of a difference between the stock screened MAF and the MBA MAF ends I have. At WOT, the stock MAF ends with the screen is still flowing 253+ (according to Freescan). I believe the MBA ends flow only +1-3% more, but I can take the readings and post them when I get the chance.
I also experienced a noticeable difference in throttle response after removing my MAF screen.
Here is some interesting data obtained by Northwestern Ohio's SuperFlow SF600 Flow Bench. They flow tested the LT1 TB with and w/o an airfoil, and they also flowed an LT1 MAF with and w/o a screen. The results are here:
