stock 93 t/a a4 w overdrive (non eletronic), 3.23 s
launch in 2nd and then shift in D?
launch in D?
shift all gears ?
launch in D?
shift all gears ?
. I figure the computer is a lot smarter and faster than me
Mods
Although I have yet to push it
13.410 @ 102.66 11/20/05]
Im going to guess it still best to stall an aftermarket converter with a higher stall?? I practice my launches almost everyday at this one stoplight and find that stalling my car has got me better launches. But going to high an rpm(right before it breaks loose about 1200-1400rpm) it doesnt seem to be better. I found that just a little stall (around 1000rpm) works best. Ive messed with alot and this worked best for me.
The entire purpose of a ordering a torque converter with a stator ratio and foot brake and/or true or footbrake stall specific to your application is so that you will have a little room to rev the motor before the converter reaches it's flash point.
I dont know lots and learning as I go so this kind of stuff really helps.
