what is the easiest way to replace fuel pump on 87 z28 5.0
easy fuel pump replacement
longNlowTags: None
Use the "trap door" method.Originally posted by InjuneerTracy
...he does have an '87, you know...Originally posted by TraceZUse the "trap door" method.
Aren't 3rd gen and 4th gen cars almost exactly the same in that area?Originally posted by Rob B (shoebox)...he does have an '87, you know...
Dont cut holes just undo the botom of the shocks and drop the tank, it does not take that long. Its better for the car. Uni-bodies arent ment to be hacked up. IMO it looks like S*#! but thats just me.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Yep, you can use the "trap door" method on 3rd and 4th gen cars. I have seen plenty of examples on both kinds of cars. I would, however, recommend at least trying it the correct way first (dropping the rear end and lowering the tank). If you're having too much trouble attempting it that way, then go for the "trap door" method. That's just my opinion.Originally posted by TraceZAren't 3rd gen and 4th gen cars almost exactly the same in that area?
Hopefully this thread won't go bad, as many "trap door" fuel pump install threads end up locked on other forums. It's the holidays everybody, can't we all get along?
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
