I'd like to install a black power antenna in my Z so the car cover is easier to deal with. I'm wondering which one I should install. Will one from a firebird fit? The angle on the quarter is different, that is why I ask.
power antenna with a black mast for Camaro?
Tags: None
Tracey
I found this site a while ago which has info on installing a power antenna on a 4th gen Camaro.
http://www.geocities.com/mdw9965/power-antenna.htm
I think the one from the T/A should fit fine. There's this little rubber piece to your panel that you have to reuse with the PA. I reused mine when I upgraded mine to PA. It was a very easy and quick installation on mine. Not sure if yours has the wiring harness + plug for it. If not it takes a little more work.
Rene97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
