Rims all screwed up
  • Rims all screwed up
    I took the rim into a curb after hitting a nice slick patch opf black ice. How unsafe is it to drive on that? Do I need a whole new rim, how much will it cost if it can be reworked? Any suggestions?
    holly crap.....
    you'll probably need to replace that wheel pretty sure....
    sorry brother,
    eddie
      I personally wouldnt drive on it
      1997 Trans AM WS6 vert
      1 of 463
      LT4 knock module
      strut tower brace
      SLP fan switch
      160* t/stat
      Pictures Here
        How expensive would that be to fix?
          Can't believe that tire still holds air with so much of the rim missing . Better not drive on it. Might find a new rim on ebay. Sorry about the bad luck man.
            Yeah, the bead of that tire is hanging on for dear life. Replace that sucker before you drive the car on the highway.
              There's an outfit called "Wheel Collision Center" in Bath, PA. They are supposed to be very good at straightening and repairing alloy wheels. I believe the cost starts at $75, but something that severe (if they could even repair it) would be in the range of $150-200. Unless that is some rare or oddball wheel that you can't replace (doesn't appear to be - looks sort of "stock"), it wouldn't be a very good idea, nor very cost effective to try and repair it. Do not drive on it like that.
              You could probably get more info from:
              www.wheelcollision.com
              1-800-292-RIMS
                The wheel is trashed. nobody will touch that repair as too much material in a critical area is missing. You'll have to search for an acceptable replacement. Most stock wheels go for the $200 range for an entire set.
                  Replace it before you even drive the car any further, unless you have a death wish or would like to repair your whole car once that tire lets go and you ditch it somewhere.
                  If you are on a budget, check with your local wreckers and see if they have one wheel. They are usually on a network so they can check if they have it somewhere else and get it for you. Make sure to have the tire mounted and balanced right there before you pay for, it just to see that the wheel is ok.
                    I'd go the boneyard route myself. You can even do that on-line these days......here's an example http://www.junkyarddog.com/
                    Dave S
                    2000 Black Camaro SS
                      Whoa!!!
                      Wow. Yeah definitely don't drive on that. If it were me I wouldn't even have my car sitting in the driveway on that, I'd throw the spare on until I got it replaced. It appears to be a "oem" wheel, which you can usually pick up pretty cheap if you look around on-line. You could check e-bay, you might be able to pick up a whole set for the price of one wheel from an online store.
                      2000 Camaro SS #3507
                      www.cardomain.com/memberpage/775745
                        how about just putting on your spare...LoL.
                        I'd rather ride around on the spare for awhile, then that rim...yikes!
                        that rim is shot...go to a salvage yard...probably can pick one just like htat for $90...if that.
                          After a good jaring like that you may want to get the alignment checked too. Maybe even a full inspection of that side just to be sure. Alot of stress is induced on the strut when hitting the botom of the wheel from the side. Check to see if you can see any movment in the bolts on the strut tower.
                          Eric W.
                          89 Firebird Formula WS6
                          Accel/Lingenfelter Super Ram
                          6.2L/382.97 ci
                          Custom PROM Dyno tuned
                          WCT-5 speed
                          BW 9-bolt Posi 3.45
                          Boss MS 18" Rims
                          Custom Dual exhaust
                          1LE upgrade
                            I agree....a buddy of mine hit the curb with the rear wheel of his IROC-Z and it bent the axle.....get an alignment for sure!!
