My ignition switch is broken. When I turn the key into the crank position it just sits there without springing back. So I pull the steering wheel off to find this notched plate, that goes around the spline, that i cannot remove. This seems to be a locking mechanism of some sort because the steering wheel lock pin inside the column fits into it when you turn the plate. The only screw I can find is the screw for the turn signal arm. I can upload pics if you need, but I cannot figure out how to get this thing off and I cannot find a how-to anywhere. I don't want to break anything. Please help!
